Downloads (Current Version)
TT-02291 and below require V12.0 recovery, before upgrading to the latest software version.
| Tiger Touch v15.1 Upgrade Installer | This is an upgrade installer: – Upgrade consoles running v15.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required.
AvoKey must be plugged in before upgrading. |
Download 465.6MB |
| Tiger Touch II v15.0 Recovery Creator | This is a recovery installer: ✘ No support for old touch screen found on Tiger Touch IIs before TT-02291. ✘ No support for Tiger Touch/Tiger Touch Pro consoles. ⚠ The consoles above can use v12.0 recovery and v15.0 upgrade installer. – Fixes occasional rendering issue while using internal Capture. – Longer and more complex install process, allow 48 hours. ⚠ Show files may be deleted, please backup first. ⚠ Only one historical software version maintained. |
Download 2.3 MB 08/10/2019 |
Documentation
| Go to Online Manual |
| Go to Release Notes |
| Go to the Recovery Creator Guide |
| Tiger Touch v15.0 Upgrade Installer | This is an upgrade installer: – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 271.3 MB |
| Tiger Touch v14.0 Upgrade Installer | This is an upgrade installer: – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 250.6 MB |
| Tiger Touch v13.0 Upgrade Installer | This is an upgrade installer: ✔ Upgrade consoles running v12.0 recovery. ✔ Faster install and simpler install experience, allow 2 hours. ✔ Does not require relicensing. |
Download 183.4 MB 06/02/2020 |
| Tiger Touch v12.1 Upgrade Installer | This is an upgrade installer: – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 170.6 MB 11/12/2019 |
| Tiger Touch v12.0 Recovery Creator | This is a recovery installer: – To downgrade to previous versions, please see release notes. – Relicensing required, please allow 48 hours for upgrade. – Show files may be deleted, please backup first. – Only one historical software version maintained. |
| Tiger Touch v11.4 Upgrade Installer | AvoKey not required | Download 110.0 MB 20/08/2019 |
| Tiger Touch v11.3 Upgrade Installer | AvoKey not required | Download 109.9 MB 18/04/2019 |
| Tiger Touch v11.1 Upgrade Installer | This is an upgrade installer: – Faster install and simpler install experience, allow 2 hours – Does not normally require relicensing. – Does not include additional performance increases from the recovery installer. |
AvoKey not required | Download 109.8 MB 17/08/2018 |
| Tiger Touch v11.1 Recovery Creator | This is a recovery installer: – Improvements to performance, recomended for large shows – Longer and more complex install process, allow 48 hours – Relicensing required, please allow 48 hours for upgrade. – Show files will be deleted, user backup of show files required. – Only one historical software version maintained |
AvoKey not required | Download 2.3 MB 26/09/2018 |
| Tiger Touch v11.0 Recovery Creator | AvoKey not required | Download 3.3 GB 02/05/2018 |
| Tiger Touch v11.0 Upgrade Installer | AvoKey not required | Download 108.7 MB 08/05/2018 |
Older Downloads
| Tiger Touch v10.1 Upgrade Installer | AvoKey not required | Download 135.8 MB 24/03/2017 |
| Tiger Touch v10.0 Recovery Creator | AvoKey not required | Download 2.9 GB 12/06/2016 |
| Tiger Touch v9.1 Upgrade Installer | AvoKey not required | Download 112.7 MB 28/07/2015 |
| Tiger Touch v9.0 Recovery Creator | AvoKey not required | Download 2.4 GB 29/04/2015 |
| Tiger Touch v8.1 Upgrade Installer | AvoKey not required | Download 104.3 MB 10/12/2014 |
| Tiger Touch v8.0 Recovery Creator | AvoKey not required | Download 2.3 MB 03/09/2014 |
| Tiger Touch v8.0 Upgrade Installer | AvoKey not required | Download 104.2 MB 26/08/2014 |
ECN’s
| Code | Title | Download |
| ECN-0209 | Arena and TT2 Wing Firmware | ECN-0209.zip |
| ECN-0204 | Fix – Failed to create bootable BIOS Stick! (Error: 2) | ECN 0204 – Windows 10.zip |
| ECN-0199 | DMC Touchscreen Controller Callibration | ECN-0199_TPOffset.zip |
| ECN-0193 | LCD Inverter Enable Delay | |
| ECN-0191 | Dongle Connection Point Change |
